Krae
Eine neue Möglichkeit der "Monetarisierung" von Leuten, die unter "Pixelpeeping" leiden, ist gefunden worden:
Neural network Image Processing Tool
Geht erstmal nur mit:
https://cam.start.canon/tc/S002/manual/html/UG-05_Synthetic_0080.html
Compatible cameras: EOS R3, EOS R5, EOS R5 C, EOS R6, EOS R6 Mark II, EOS R7, EOS R10, or EOS-1D X Mark III
Using the Neural network Image Processing Tool (hereafter, “the tool”), you can apply the following image processing to supported images ().
[Neural network Noise Reduction]
Noise reduction
[Neural network Lens Optimizer]
Digital Lens Optimizer
[Neural network Demosaic]
Suppression of jaggies, moiré, and false colors
Before using the tool, you will need to download it to your computer and purchase a subscription.
The tool can be used for RAW images (except those captured in RAW burst mode, or RAW movies) from compatible cameras. Note that [Neural network Lens Optimizer] can be applied to images from the following cameras.
RF14-35mm F4 L IS USM
RF15-35mm F2.8 L IS USM
RF24-70mm F2.8 L USM
RF24-105mm F4 L IS USM
RF24-105mm F4-7.1 IS STM
RF70-200mm F2.8 L IS USM
RF70-200mm F4 L IS USM
RF400mm F2.8 L IS USM/EXTENDER RF1.4x/EXTENDER RF2x
RF600mm F4 L IS USM/EXTENDER RF1.4x/EXTENDER RF2x
RF-S18-45mm F4.5-6.3 IS STM
RF-S18-150mm F3.5-6.3 IS STM
