Z Softwareupdate Z50, Z5, Z6, Z7, Z70-200
Nikon just released new firmware updates for the Z50, Z5, Z6, Z7 mirrorless cameras, the Nikkor Z 70-200mm f/2.8 lens, and the WR-1 wireless remote controller:
Nikon Z50 Firmware Version 2.20
• Added support for:
• FTZ II mount adapters, and
• NIKKOR Z 24-120mm f/4 S lenses.
• Improved face/eye detection performance and the visibility of subjects in pictures taken using an optional flash unit.
Nikon Z5 Firmware Version 1.20
Nikon Z6 Firmware Version 3.40
• Flicker is less likely to appear in the display during filming when N-Log or RAW footage is recorded to external HDMI video recorders at low light levels.
• Improved eye detection performance for Auto-area AF and Wide-area AF (L).
• Increased the refresh rate for the focus point displayed during face/eye-detection and subject-tracking AF.
• Fixed the following issues:
• The camera would sometimes stop responding when Auto was selected for Set Picture Control in the PHOTO SHOOTING MENU.
• The camera would sometimes exceed the value selected for ISO sensitivity settings > Maximum sensitivity in the MOVIE SHOOTING MENU.
Nikon Z7 Firmware Version 3.40
NIkkor Z 70-200mm f/2.8 VR S Firmware Version 1.20
• Added support for the following features when the lens is mounted on a Z 9:
• Camera and lens VR are synchronized for improved vibration reduction (synchro VR).
• When an option other than Non-linear is selected for Custom Setting f9 (Focus ring rotation range), the focus ring responds linearly to focus changes between the minimum focus distance and infinity, regardless of the speed with which the ring is rotated.
• Fixed an issue that in rare instances would result in hybrid autofocus halting at the minimum focus distance during contrast-detect AF.
Nikon WR-1 Firmware Version 1.04
• Added support for the Z 9. When used with the Z 9, the product supports display and selection of shutter speeds as fast as 1/32,000.
Beim ersten kurzen Test mit der Z6 kommt mir die Augenerkennung auf jeden Fall fixer vor. Ähnlich wie bei meiner Z6II. Allerdings nach wie vor keine Augenerkennung bei Wide Area L. Das ist bei Reportagen mein bevorzugter AF Modus bei der Z6II.
Entweder wird dies bei der Z6 nicht angezeigt, oder es funktioniert tatsächlich nicht.
Ich vermute mal, sie haben das hauptsächlich wegen dem FTZ II und dem 24-120 heraus gebracht. Aber wieso braucht es ein Firmware-Update bei einer neuen Linse?
Hoffen wir mal, dass das eine Ausnahme ist und man nicht in Zukunft bei jeder neuen Z Linse auch ein Firmware-Update für die Kamera braucht.
Ist ja ein bisschen traurig von Nikon, wenn sie das in die Release Notes rein schreiben und es dann nicht tut. :(
Ich hoffe ja mal, dass das tatsächlich noch ein kleiner Bug ist und nicht, dass da ein unaufmerksamer MA die FW-Notes der IIer per copy-and-paste zur Z6 gepackt hat und Nikon zurückrudern muss.
Leider immer noch keine Verlängerung der Belichtungszeiten über 30s. wie bei der II Generation
Ja, das finde ich auch sehr schade! Sowas müsste doch einfach software-technisch zu bewerkstelligen sein. :(
Ansonsten freue ich mich natürlich über jedes Firmwareupdate. Hätte ich nicht erwartet, für meine "alte":lol: Z6...
Auf jeden Fall springt der Augen-Af viel schneller an und ist auch deutlich fixer. Ob sich die Treffergenauigkeit auch erhöht, konnte ich noch nicht testen.
Mittlerweile machen das ja zum Glück einige Hersteller so. Die Einzigen die früher immer viel gelobt wurden waren Fuji, die haben aber meiner Meinung nach ziemlich abgebaut, was FW Updates betrifft.
Welche denn? Canon und Sony habe ich da nicht positiv in Erinnerung was regelmässige FW-Updates zur ihren Kameramodellen anbelangt, vor allem wenn es um Verbesserungen oder neue Features geht.
