    Thema: "Plastik (Kunststoff)"
Daten aus Exif entfernen
Heiderbacher
Hallo, ich habe gerade mal bei meiner Fuji X-T20 geschaut was da so an Exif-Daten rauskommen, allerhand:
Code:
File Name
Directory
File Size
File Modification Date/Time
File Access Date/Time
File Inode Change Date/Time
File Permissions
File Type
File Type Extension
MIME Type
Exif Byte Order
Processing Software
Make
Camera Model Name
Orientation
X Resolution
Y Resolution
Resolution Unit
Software
Modify Date
Artist
Y Cb Cr Positioning
Copyright
Exposure Time
F Number
Exposure Program
ISO
Sensitivity Type
Exif Version
Date/Time Original
Create Date
Components Configuration
Compressed Bits Per Pixel
Shutter Speed Value
Aperture Value
Brightness Value
Exposure Compensation
Max Aperture Value
Metering Mode
Light Source
Flash
Focal Length
Version
Internal Serial Number
Quality
White Balance
Saturation
White Balance Fine Tune
Noise Reduction
High ISO Noise Reduction
Fuji Flash Mode
Flash Exposure Comp
Focus Mode
AF Mode
Focus Pixel
Slow Sync
Picture Mode
Exposure Count
Shadow Tone
Highlight Tone
Shutter Type
Auto Bracketing
Sequence Number
Blur Warning
Focus Warning
Exposure Warning
Dynamic Range
Film Mode
Dynamic Range Setting
Development Dynamic Range
Min Focal Length
Max Focal Length
Max Aperture At Min Focal
Max Aperture At Max Focal
Image Stabilization
Rating
Image Generation
Image Count
Faces Detected
Num Face Elements
User Comment
Flashpix Version
Color Space
Exif Image Width
Exif Image Height
Interoperability Index
Interoperability Version
Focal Plane X Resolution
Focal Plane Y Resolution
Focal Plane Resolution Unit
Sensing Method
File Source
Scene Type
Custom Rendered
Exposure Mode
Focal Length In 35mm Format
Scene Capture Type
Sharpness
Subject Distance Range
Serial Number
Lens Info
Lens Make
Lens Model
Lens Serial Number
GPS Version ID
GPS Altitude Ref
GPS Map Datum
PrintIM Version
Compression
Thumbnail Offset
Thumbnail Length
XMP Toolkit
Creator Tool
Current IPTC Digest
Originating Program
Program Version
Preview Image Width
Preview Image Height
Preview Image
Image Width
Image Height
Encoding Process
Bits Per Sample
Color Components
Y Cb Cr Sub Sampling
Aperture
GPS Altitude
GPS Latitude
GPS Latitude Ref
GPS Longitude
GPS Longitude Ref
GPS Position
Image Size
Megapixels
Preview Image Size
Scale Factor To 35 mm Equivalent
Shutter Speed
Thumbnail Image
Circle Of Confusion
Field Of View
Focal Length
Hyperfocal Distance
Light Value
Da ich manche Bilder auch gerne im Internet veröffentlichen würde, würde ich aber gerne Exif-Einträge die einzigartig sind, gerne vorher rauslöschen. Das wären dann in diesem Fall Dinge wie Serial Number, Lens Serial Number und Image Count (vielleicht auch noch mehr).
Wie mache ich das am bequemsten? Geht das irgendwie mit Digikam oder mit Darktable. Am besten in einer Stapelverarbeitung, so dass ich quasi nur sage, dass diese und jene Bilder exportiert werden sollen für diesen und jenen Zweck und dann dementsprechend behandelt werden? Also bspw. bei den Bildern für das Veröffentlichen im Internet dann die oben genannten Daten entfernen.
Beispiel mit ExifTool (Freeware) im Mac-Terminal oder der Windows-Eingabeaufforderung:
Seriennummern in einem Ordner löschen:
Code:
exiftool -*serial*= *.JPG *.RAW
RAW durch deine RAW-Dateiendung ersetzen, also „ORF‟, „CR2‟ usw.
Klar, exiftool kenne ich. Dachte nur, dass es vielleicht was integriertes gibt. Wenn man eh schon darktable oder so anwirft, dann wäre es toll wenn man einfach einen Knopf drückt, auswählt für was man die Bilder möchte und entsprechend werden sie editiert. Also beim einen gewisse Exifs raus. Beim anderen vielleicht noch welche rein und die Bilder verkleinern und umbenennen, etc.
Du solltest bei solchen Operationen immer beachten, dass dabei die Herstellerinfos in den EXIF-Daten kaputt gehen können. Also nur auf Kopien anwenden.
Geht eigentlich ganz einfach mit dem JPG Illuminator.
Kann man aus LR starten und das Bild dann (ggf. für das Forum verkleinern) und mit der Einstellung "für's Web speichern" abspeichern.
Da sind dann keine EXIFs mehr drin.
Image Count geht aber bspw. nicht aus den Daten raus... :cool:
Ich will ja eben nicht alle löschen, sondern nur Daten, die quasi eindeutig sind und eine eindeutige Zuordnung zur Person zulassen.
Da Du von manchen Fotos im Eingangsposting schreibst- also nicht jede Aufnahme- speichere doch einfach die Bilder ohne exifs (in PS "Speichern für Web"...) und gib in den Beiträgen wo Du Deine Aufnahmen zeigst die wenigen Infos per Hand ein (ISO, Brennweite, Blende...).
Das wäre sicher, daß Dir mal nicht etwas durch die selbstgewählte Beschränkung fällt.
Naja, ein paar mehr werden es schon sein. ;)
Aber habe nun auch rausgefunden, dass man mit exiftool die Felder auch einfach überschreiben kann. DIe mit "serial" löschen und ImageCount bspw. einfach mit einer beliebigen Zahl überschreiben. Ich denke das wäre dann wohl die Lösung für mich.
